Multiple Instance - uninstall shows installer dialog
dlee021772
Post by dlee021772 »
Hi All,
I decided to try the Sample Multiple Instance - since this was an issue on our product installer. I am finding that if I install two instances of the same product, the second instance uninstaller in Control Panel, shows the standard installation dialog, rather than the uninstall. I am on X3. Do you know if there is a fix for this?
Also, I have noticed that on our product installer, the Apply Install indicates complete, but I know it didn't install anything in the instance folder.
Daniel
Re: Multiple Instance - uninstall shows installer dialog
Dear Daniel,
honestly I don't see the issues you are reporting.
I don't know if you made any modification to the project that may cause the issues you seem to have.
If you have a chance to post a very minimal project the replicates the issue, I'll have a look.
