Hi.
Has anybody except me problem with new plug-in MS SQL Instances?
I am trying InstallAware Studio 6 and i have a problem with "MS SQL Server connection" example, I don't know why, but this example doesn't work corect.
Concrete problem - sometimes MS SQL Instances doesn't return corect result, it returns nothing! The same example work correct on one computer, on second no!
MS SQL Instances
This plug-in uses network connections. Make sure you do not have firewalls or other software potentially blocking connections - they might be the culprit in the errant behavior.
I tryed it on 4 PCs connected to network. PC1 - there is SQL Server 2000.
I'm able to connect PC1/SQL Server 2000 from PC2(WXP SP2) but not from PC3(WXP SP2) and not from PC4 (W98).
I turned off the firewall too, installed MSDE 2000 on the localhost tryed plug-in on localhost, but result of SQL Instances on PC3 is nothing!
Did you enable network protocols and mixed mode auth on the instances you are trying to connect to?
Both plug-ins use the exact same connection mechanisms - in fact, they are built on the same code base.
Users browsing this forum: Google [Bot] and 74 guests
