Code signing with InstallAware
jessican
Post by jessican »
Hi!
So, I've been going through the tutorial here on how to implement code signing for InstallAware.
http://www.installaware.com/blog/?p=416
I've hit a bump though.. the instructions say "1. In the Project Options dialog (“CTRL+SHIFT+F11”) select the “Post-Build” event node listed within the left tree pane control. Then in the Commands field enter the following command line sequence...."
Unfortunately, I have InstallAware Developer... and "Build Events are available only with InstallAware Studio and above."
So... how do I Sign my package and comply with Microsoft's New Code Signing Policy?
Is there an alternate approach to the build events?
Please let me know how I should do the code signing with developer edition..
Re: Code signing with InstallAware
Dear Jessican,
which is your IA version?
jessican
Post by jessican »
I have the X3 Developer version!
Dear Jessican,
I asked for the version because IA X4 complies with the new "Code Signing Policy".
Unfortunately in your case the possible option is to follow the steps described with the following link.
http://www.installaware.com/forums/view ... =2&t=10575
Alternatively, you may use Microsoft "Signtool" to sign your package from command line.
jessican
Post by jessican »
It does! Thank you!
:D
