InstallAware is editing source XML-Files
Weatherlights
Post by Weatherlights »
Hey,
I recently developed a small test project to test XML-Files. I created the Installer with the Designer and added an XML-File. I then used the XML Files Tool to make some changes. I compiled the installer. The $TARGETDIR$ was $MYDOCUMENTS%\$TITLE$.
I just tested the installer and as soon the installation finished the source (!) XML-File looked like the target XML-File (which was also created).
I have to say that is is highly odd...
And also I can not edit the Action (Create Only) because it is greyed out and since I have the express edition I can not edit the script file.
Re: InstallAware is editing source XML-Files
Dear Weatherlights,
can you post a very minimal project that replicates the issue?
I'll have a look.
