X4 EVAL Plugin Problem?
QooScho
Post by QooScho »
I have switched my MSI code from IA17 to X4. There is a line with Eval Plugin to check if a software is installed or not.
This works fine with IA17.
Eval NOGSWINFILE = $GSWINFILE32$="NOTFOUND" and $GSWINFILE64$="NOTFOUND"
But now after build with X4 and executing the new setup I receive this error:
Invalid syntax: ""NOTFOUND"=""NOTFOUND"" and ""=""NOTFOUND""
See attached screenshots for details:
Is there a problem with Eval and X4?
best regards
Hans
Re: X4 EVAL Plugin Problem?
Dear Hans,
I don't believe this is an InstallAware plugin ... you should contact the developer directly.
PLEASE NOTE!
This topic has been moved to the more appropriate "Plug-In Development" forum.
QooScho
Post by QooScho »
Dear Francesco
I thought the Camelot Installaware Plugins are offical plugins?
I found this old link:
http://www.installaware.com/forums/viewtopic.php?t=81
regards
Hans
Dear Hans,
that one is an old plugin released by a third party vendor. Honestly I do not know if they have ever made an updated version of it.
Very probably that plugin version doesn't support latest IA versions.
You should contact them directly.
QooScho
Post by QooScho »
Dear Francesco
I have contacted Camelot but have not received an answer yet.
Other question:
How can you do such a Expression without the Eval Plugin
If(Variable1 = "") and (variable2 = "") ?
In installaware there is no "AND" operator.
best regards
Hans
Dear Hans,
you may use the "Evaluate Expression" command.
