Writing to Wow6432 registry on 64bit Windows...
Edhy
Postby Edhy » Tue Jul 05, 2016 10:53 am
I have a 32bits installation created using the Basic Wizard. This setup may also be run on a 64bit OS and when that is the case, I need to write some registry keys under the HKLM\SOFTWARE\WOW6432 key, but on 32 bits OS these keys should install on HKLM\SOFTWARE, I have the following code:
Here is the Plain Text Clipboard Data
    Comment: ER: Write Registry Keys based on the OS processor
    if Variable ISWINDOWS64BIT Equals TRUE
      Comment: ER:  If on x64 force it to write to the WOW6432 node.
    Write Registry Key HKLM\SOFTWARE\KineticJump\AppLifeUpdate\ApplicationSettings\$DEV_APPLIFEUPDATE_APPLICATIONID$\LogDirectory, $TARGETDIR$\UpdateLogs
    Write Registry Key HKLM\SOFTWARE\KineticJump\AppLifeUpdate\ServiceKeys\$DEV_APPLIFEUPDATE_APPLICATIONID$\Path, $TARGETDIR$\TBRUtils.exe
    Write Registry Key HKLM\SOFTWARE\KineticJump\AppLifeUpdate\ServiceKeys\$DEV_APPLIFEUPDATE_APPLICATIONID$\PublicKey, $AppLifeUpdate_PUBLIC_KEY$
      Comment: ER: Set the OS to x64
Here is the InstallAware Clipboard Data
~InstallAware Clipboard Data~
~End~
~{8E4A8DAB-0311-46EE-94F8-F00495CB2450}~
~Set 64 Bit Mode~
~{241CB02B-2B3B-469D-9C49-445DC9EA9A2A}~
~FALSE~
~FALSE~
~TRUE~
~Comment~
~{6B5A19ED-4E09-4B75-B0C2-40A2F6E75D31}~
~ER: Set the OS to x64~
~If~
~{384E09E0-3FD4-4BA9-9182-DDF6F6D01E38}~
~ISWINDOWS64BIT~
~0~
~TRUE~
~FALSE~
~Comment~
~{68C566D8-2040-46D0-AACD-9CB7EF77DFE9}~
~Write Registry~
~{A9FE0D13-D7FE-4AC6-80AD-173225CCE806}~
~0~
~2|~
~SOFTWARE\KineticJump\AppLifeUpdate\ServiceKeys\$DEV_APPLIFEUPDATE_APPLICATIONID$~
~PublicKey~
~$AppLifeUpdate_PUBLIC_KEY$~
~TRUE~
~FALSE~
~Write Registry~
~{96CD90DF-628E-43B4-8F0E-99041E2776EE}~
~0~
~2|~
~Path~
~$TARGETDIR$\TBRUtils.exe~
~TRUE~
~FALSE~
~Write Registry~
~{4C9E6C16-23C4-4CBB-BDBA-F54173855BA9}~
~0~
~2|~
~SOFTWARE\KineticJump\AppLifeUpdate\ApplicationSettings\$DEV_APPLIFEUPDATE_APPLICATIONID$~
~LogDirectory~
~$TARGETDIR$\UpdateLogs~
~TRUE~
~FALSE~
~End~
~{CE8DCF6C-C797-49A1-B2BB-7B3CF2147C04}~
~Set 64 Bit Mode~
~{2704416B-FB17-48B4-97FD-B9BD601395C1}~
~TRUE~
~FALSE~
~FALSE~
~Comment~
~{28DDE3F1-B9BE-4CAA-9FBF-DF46A3936415}~
~ER:  If on x64 force it to write to the WOW6432 node.~
~If~
~{81ACBC07-932B-47EE-B563-EA8ECC9BE91F}~
~ISWINDOWS64BIT~
~0~
~TRUE~
~FALSE~
~Comment~
~{AF13212E-08E9-430B-B822-6F0CFCA5AD5D}~
~ER: Write Registry Keys based on the OS processor~
What I am seeing in my test, is that when running on 32bits OS, it will create the keys properly on HKLM\SOFTWARE\ but when running on x64 OS, it will also write the keys on HKLM\SOFTWARE\ instead of HKLM\SOFTWARE\WOW6432.
This section of the code is before the Apply Install command.
What am I doing wrong here?
Thanks!!!
Edhy Rijo
Re: Writing to Wow6432 registry on 64bit Windows...
Postby FrancescoT » Tue Jul 05, 2016 12:08 pm
Dear Edhy,
if the code you posted gets executed before Apply Install, it'll never write a key under "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node".
You are switching back to 64 Bit mode before Apply Install statement.
Write Registry command is a Windows Installer command (PURPLE COMMANDS) and it's effective execution is deferred to Apply Install execution.
http://www.installaware.com/forums/viewtopic.php?f=2&t=4338#p14960
Edhy
Postby Edhy » Tue Jul 05, 2016 12:39 pm
Hi Francesco,
Thanks for the link on the "PURPLE COMMANDS" very good even though not straight answer on how to deal with my current issue.
I found a way to do this by using the NATIVE ENGINE and then manually deleting the keys when uninstalling, here is the code:
Create Registry Keys:
      Comment: ER:  If on x64 configure NATIVE_ENGINE to force it to write to the WOW6432 node immediately not matter the Apply Install .  These keys will need to be removed manually when Uninstalling
      else
Then before Apply Uninstall I got this:
  Comment: ER: Delete Registry Keys based on the OS processor
    Delete Registry KEY HKLM\SOFTWARE\KineticJump\AppLifeUpdate\ApplicationSettings\$DEV_APPLIFEUPDATE_APPLICATIONID$\*.*
    Delete Registry KEY HKLM\SOFTWARE\KineticJump\AppLifeUpdate\ServiceKeys\$DEV_APPLIFEUPDATE_APPLICATIONID$\*.*
So far, I test it on Windows 7 x86 and x64 and seems to work fine. Please let me know if you see anything out of order that may not work.
Thanks again!!!
Edhy Rijo
Postby FrancescoT » Wed Jul 06, 2016 12:20 pm
Dear Edhy,
for what I see it looks correct!
Users browsing this forum: No registered users and 87 guests
