MessageBox and Dialog
Arthur
Postby Arthur » Wed Jul 06, 2016 5:53 pm
I have a custom Dialog that has a radial button. The radial button calls a variable to display a MessageBox after clicking on Next.
The MessageBox displays correctly, but the Dialog is still in view. How can I remove the Dialog box and just show the MessageBox. I added a Hide Dialog right before the MessageBox, but did not work.
I've attached the custom Dialog.
~InstallAware Clipboard Data~
~End~
~{6306B391-7413-464C-B0C4-04050A1F8A59}~
~Terminate Install~
~{D715E657-A8CC-4BF4-AD2B-EC8D30ED236F}~
~If~
~{7A141190-C253-49F0-B136-EC56E205814B}~
~WIZARD~
~0~
~CANCEL~
~FALSE~
~Comment~
~{9ED9EDDF-0D96-4624-B142-1B126620D82C}~
~Exit Setup if Wizard Loop cancelled~
~Label~
~{43877A9A-6C4A-4792-91CA-BF1DDB2EFD0A}~
~Main Install~
~Comment~
~{744D3B38-C0D4-43DB-834D-2599C8023F29}~
~End~
~{A86BE49F-3AB7-4ADE-A9D8-7F2718CC20AD}~
~MessageBox~
~{D7D4B0D1-1751-4904-A013-7416EF9F5FD1}~
~Uninstall!~
~0~
~1~
~If~
~{D770ECD4-AA11-4CDA-805C-2DE5C8E45A39}~
~UNINSTALL~
~0~
~TRUE~
~FALSE~
~Hide Dialog~
~{A4891CED-C7C4-4CE0-A313-02B5EAE0F1C1}~
~Comment~
~{F7661B54-92EA-4FBD-A2F9-4CDC4AE6434C}~
~Display Dialog~
~{F6F528FE-F96E-4942-B110-B6035F28035E}~
~Farmers_Uninstall_Exit~
~WIZARD~
~TRUE~
~TRUE~
~FALSE~
~Comment~
~{0A9F41FB-BB0B-45DB-9352-D21B4B62E9A8}~
~Set Variable~
~{116324DB-0B24-4850-B766-732011C7CCA1}~
~UNINSTALL$MYAH$MYAH$FALSE~
~FALSE~
Dialog MessageBox Test.7z
(341.62 KiB) Downloaded 333 times
Re: MessageBox and Dialog
Postby FrancescoT » Thu Jul 07, 2016 1:37 pm
Dear Arthur,
the Hide Dialog command can be only used with Modeless Dialogs.
The one you use is a Modal Dialog and this remains active, until another Dialog gets displayed or if the process itself terminates.
This happens because the last active Modal Dialog becomes the main Windows of the running process.
Arthur
Postby Arthur » Thu Jul 07, 2016 1:41 pm
That helps. Thank you.
Postby FrancescoT » Mon Jul 11, 2016 12:11 pm
:D
Users browsing this forum: No registered users and 101 guests
