Frustrated with a simple if statement comparing versions
Arthur
Postby Arthur » Thu Jul 07, 2016 11:29 am
I'm having an issue with an If statement when comparing version numbers. I have a very simple script for testing.
The version in my registry and the version to compare against is the same. In the If statement, I should be getting the MessageBox "No need to upgrade", but I am not.
Does anyone have any suggestions?
Define Component: Native Setup
Set Variable VERSION_CHECK to 22.0.0.192
Read Registry Key HKLM\SOFTWARE\Macromedia\FlashPlayerActiveX\Version into VERSION_REGISTRY
MessageBox: , VERSION_CHECK: $VERSION_CHECK$$NEWLINE$$NEWLINE$VERSION_REGISTRY: $VERSION_REGISTRY$
if Variable VERSION_REGISTRY Greater Than (Version) $VERSION_CHECK$
 MessageBox: , No Need to upgrade
 else
 MessageBox: , Need to upgrade
Terminate Installation
~InstallAware Clipboard Data~
~Terminate Install~
~{A696F45A-D7FE-4BEE-A223-1FB7A97B6DD1}~
~Comment~
~{6F68447A-7A2F-4D0A-B8EF-CFDFDF8B5795}~
~End~
~{5E3307C7-5A25-4C50-BE9E-8A6A65C1A111}~
~MessageBox~
~{8CAEAE8E-AB27-47FD-9205-3EA1E0E8B5BB}~
~Need to upgrade~
~0~
~2~
~Else~
~{8A394F6E-0974-4547-857B-497BC14AFCEA}~
~MessageBox~
~{319F5974-8DA9-4FE5-8A29-CE993E3CA61D}~
~No Need to upgrade~
~0~
~2~
~If~
~{B5F34C3C-5B10-4720-AD32-B366090FC916}~
~VERSION_REGISTRY~
~6~
~$VERSION_CHECK$~
~FALSE~
~Comment~
~{451768FA-5291-488F-82E2-53D431C8AD99}~
~MessageBox~
~{C9959FD0-C51B-45E4-B26C-184BCE45D97A}~
~VERSION_CHECK: $VERSION_CHECK$$NEWLINE$$NEWLINE$VERSION_REGISTRY: $VERSION_REGISTRY$~
~0~
~1~
~Comment~
~{E361AF78-8369-4D4E-B0AD-49779A77CF90}~
~Read Registry~
~{35B10BAB-893B-4CF5-8CDE-00D66FC853D6}~
~VERSION_REGISTRY|~
~2~
~SOFTWARE\Macromedia\FlashPlayerActiveX~
~Version~
~Comment~
~{72A5A6A0-E228-4EAA-B6A4-5E0DBFF83FA9}~
~Set Variable~
~{794D2D49-330E-4D42-B4FE-C5BB86475F2D}~
~VERSION_CHECK$MYAH$MYAH$FALSE~
~22.0.0.192~
~Comment~
~{EDC6C120-345B-4E84-AC6A-E9FEA8F70720}~
~Define Component~
~{71C297CB-4ED6-4ED5-958C-131E0F2848A6}~
~Native Setup~
~TRUE~
~Description for #TITLE#~
Re: Frustrated with a simple if statement comparing versions
Postby FrancescoT » Thu Jul 07, 2016 12:18 pm
Dear Arthur,
I don't know which is the effective value returned by your registry key, but version comparing works fine.
Just tried this;
~Comment~
~{F4CA5CD5-EC21-4735-8D86-D1E8D86FC530}~
~End~
~{94D29424-029E-4301-8BC9-118D3AC790D9}~
~MessageBox~
~{A9863DEA-09EB-42AD-AA2A-86259780B3CF}~
~It's lower!~
~0~
~2~
~Else~
~{4D5E5980-49B8-4A80-AE5A-97C9BA786D6B}~
~MessageBox~
~{A38CC4D1-6CFE-4101-B802-AED112AF097D}~
~It's Greater!~
~0~
~2~
~If~
~{481EBB9D-DA1C-4E0B-960A-4464659116E8}~
~LOWER_VALUE~
~6~
~$VERSION_CHECK$~
~FALSE~
~Comment~
~{10CF5227-0649-42E8-89DE-CAEA4C68EE03}~
~End~
~{1DB8E0E7-6F10-4991-A7C7-67F117903E9C}~
~MessageBox~
~{6AB2DD45-31CB-4C57-ABA9-9F9B1BB9155D}~
~Need to upgrade~
~0~
~2~
~Else~
~{F9B496A9-E947-4426-B63E-322FC2A94034}~
~MessageBox~
~{A5C59003-D53F-4E77-BC3C-C6D190004495}~
~It's Greater!~
~0~
~2~
~If~
~{A7C581C3-1E63-4E10-ADF9-BA27625FAF85}~
~GREATER_VALUE~
~6~
~$VERSION_CHECK$~
~FALSE~
~Comment~
~{27F2F182-EDF5-4802-A815-50D1E3610490}~
~MessageBox~
~{7F2A5339-0FBA-466A-B729-54923E82B443}~
~VERSION_CHECK: $VERSION_CHECK$$NEWLINE$$NEWLINE$GREATER_VALUE: $GREATER_VALUE$$NEWLINE$$NEWLINE$LOWER_VALUE: $LOWER_VALUE$~
~0~
~1~
~Comment~
~{BE8706B0-033D-4AF0-8A2E-3AAC721AFDD3}~
~Set Variable~
~{943358FA-57C0-4DBD-BB38-2E3F2FE3A5E8}~
~LOWER_VALUE$MYAH$MYAH$FALSE~
~22.0.0.101~
~Set Variable~
~{41CC75E1-667E-4747-9E59-E5558C268F63}~
~GREATER_VALUE$MYAH$MYAH$FALSE~
~22.0.0.198~
~Set Variable~
~{A9C964A2-85DF-4E6D-862D-83D8C8B20272}~
~22.0.0.192~
Set Variable GREATER_VALUE to 22.0.0.198
Set Variable LOWER_VALUE to 22.0.0.101
MessageBox: , VERSION_CHECK: $VERSION_CHECK$$NEWLINE$$NEWLINE$GREATER_VALUE: $GREATER_VALUE$$NEWLINE$$NEWLINE$LOWER_VALUE: $LOWER_VALUE$
if Variable GREATER_VALUE Greater Than (Version) $VERSION_CHECK$
  MessageBox: , It's Greater!
  else
if Variable LOWER_VALUE Greater Than (Version) $VERSION_CHECK$
  else
  MessageBox: , It's lower!
Arthur
Postby Arthur » Thu Jul 07, 2016 2:58 pm
Your example works for me also.
The difference is that I am reading the registry for a String value and storing in $VERSION_REGISTRY$ variable.
If you by chance have Adobe Flash Player ActiveX installed, can you also try reading the same registry key or another registry key that has a String value?
Is there something I need to do after reading a registry key that I am not doing?
Arthur
Postby Arthur » Thu Jul 07, 2016 3:06 pm
I think I know what is happening.
The $VERSION_CHECK$ Variable and the $VERSION_REGISTRY$ value is the same for me.
I modified yours where I made the $VERSION_CHECK$ and $GREATER_VALUE$ the same and had the same issue.
In this situation, the value might be less, equal, or greater. How should I best approach the script? Greater or equal do no thing. If is less than, upgrade?
Postby FrancescoT » Fri Jul 08, 2016 9:51 am
Dear Arthur,
...maybe I am missing something, but if you only need to do "something" when a A value is less than B value, just evaluate this condition. If this is true then do something.
