Patch folder has many subfolder and exes
kishorkk23
Post by kishorkk23 »
I have created a patch for my installation of 54Mb(Single install). I modified a single file and created a patch for the same.
I see that patch folder has many subfolders like
Base Package 1
project1.msp.repack
project.msp.tmp
Upgraded Package , along with other files like
mia.lib
project1.exe
project1.msp
project1.msg.log
project1.pcp
project1.res
sfx.7zip
sfx.txt
Also the size of this folder is 840 MB . Why are there so many files created and which is the actual patch file that can be distributed?
Re: Patch folder has many subfolder and exes
Dear kishorkk23,
I suppose you enabled "Leave debug files" in the project settings of your patch project. This is probably why you have so many files left in your patch release folder.
You only need to distribute the generated "patch.exe" file.
kishorkk23
Thank you. :)
:D
