I have a native engine install which seems to do just fine.
When I go to uninstall it I get the attached pop-up to identify the original setup sources. I tried selecting the folder with the install program but it keeps coming back to this panel.
What might I be doing wrong so that I cannot uninstall smoothly... or at all?
Thank for any help.
George
uninstall not working for native engine install
wxperson99
- uninstall.jpg (317.78 KiB) Viewed 2572 times
wxperson99
Re: uninstall not working for native engine install
I believe I have found the problem... the additional uninstall code I execute referenced an executable that does not exist.
Once I correct this.. it seems to work just fine.
George
George
