How to create an install with NO uninstall option
wxperson99
Post by wxperson99 »
I sometimes have a small installation project that just reloads a file or two to a customers PC... usually to fix a problem they may be having.
How can I create this install so that it does not show up in the control panels programs and features list?
George
Re: How to create an install with NO uninstall option
Dear George,
honestly, I suppose you posted an identical question some time ago.
http://www.installaware.com/forums/view ... try#p39939
At any rate and in case you need a very minimal package, which doesn't include any dialog and which only executes a series of commands over the target machine, you may create a project from the "Blank" project template.
A blank project doesn't contain anything by default and it doesn't create any MSI file ... it's just a "blank" script.
wxperson99
You have a better memory than I do. I must be getting too old for this :-)
I did try to do a search but must not have used the correct search words.
In any case.. thanks for the quick reply here on a Friday.
George
