System Directory
Ram
System Directory
Postby Ram » Fri Jul 22, 2016 1:40 am
How can I fetch System directory?
If the system under installation is 32 bit, then I should get "C:/windows/System32" or if it is 64bit, then I should get "C:/Windows/SysWoW64".
I want to register mscomctl.ocx
Pls let me know how to go about?
Thanks in Advance
bokkie
Re: System Directory
Postby bokkie » Fri Jul 22, 2016 2:29 am
Add a Get Folder Location statement to your MSIcode. Select the System->System Directory item from the folder pulldown and return its value in a variable. That'll give you the information you're looking for.
Ram
Postby Ram » Fri Jul 22, 2016 3:11 am
Thanks a lot
Users browsing this forum: Google [Bot] and 48 guests
