Detecting Windows Server R2 Core
I'm using IA18 and have support for Windows Server 2012 R2 server. However, we need to add code to detect if the server is Core (no-gui) or not. I'm curious if there is an API support to detect "Core" with IA. Any suggestion.
ExchA
Re: Detecting Windows Server R2 Core
Dear Mdavtec,
you may have a look at the following topic.
http://www.installaware.com/forums/view ... nEx#p34106
Hi Francesco,
Thanks for response.
The method of using GetVersion() win api via "CALL DLL FUNCTION", that link suggests, doesn't work here. It doesn't distinguish between gui and core (non-gui) version of the server operation system. I ended up using method described in https://msdn.microsoft.com/en-us/librar ... s.85).aspx.
ExchA
Happy you solved!
