New Install Wizard UI cut off
DiscoLfo
Post by DiscoLfo »
When using the new install wizard from Studio Admin X5
Please see attached screen cap
Running on windows 10
X5 InstallWizard.png (37.28 KiB) Viewed 3791 times
Re: New Install Wizard UI cut off
Did you reproduce the problem having your DPI settings at 100%?
DiscoLfo
Post by DiscoLfo »
Yes at what ever DPI I set the display to it is truncated at the bottom, actually worse at 100%, I can use the dialog at 125% but at 100% the whole bottom row is cut off
Cheers
I have informed our dev team about the issue.
At any rate, please note, the New Project Wizard is deprecated. The Quick Start Wizard is the recommended way of creating setups moving forward.
