UPDATE.INI Documentation
PetriSuominen
Postby PetriSuominen » Fri Sep 02, 2016 12:06 pm
Sorry if this has already been covered, but I could not find anything with the search.
Is there any documentation about the different parameters that the update.ini file can have ?
I know there is the whitepaper, that in general terms describes how the web update functionality works, but I am looking for what different options I could tweak.
br,
Petri
Re: UPDATE.INI Documentation
Postby FrancescoT » Mon Sep 05, 2016 4:32 am
Dear Petri,
the "updates.ini" gets automatically generated by the IA IDE. So if you want to see which are the different options available with the file, just define a new "Update Pack" from the IA IDE (Web Updates -> Update Packs). All supported options are those that can be entered from the "Update Packs" dialog.
Users browsing this forum: No registered users and 199 guests
