Does File Exist with wildcard
mdavtec
Postby mdavtec » Thu Sep 15, 2016 7:11 am
I'm adding code to copy files, if exists, to a backup folder. I want to check if a folder has any file with .log extension. I'm trying to use "Does File Exist" with wildcard (*.log). but it doesn't like it. Any alternative to "Does File Exist" command? Any suggestion?
ExchA
Re: Does File Exist with wildcard
Postby FrancescoT » Thu Sep 15, 2016 11:25 am
Dear Mdavtec,
of course you cannot use Wildcards with the "Does File Exist" command.
You should use the "Find All Files" command instead ... and this will accept wildcards.
Users browsing this forum: Google [Bot] and 211 guests
