Question: sfx.7zip.tmp
mikKummerfeld
Postby mikKummerfeld » Wed Sep 21, 2016 10:57 am
Hey Guys,
I have a batch file on my desktop to create a setup via miabuild.exe.
It works perfectly, but after upgrade from IA 18 to IA X5 I have the following problem:
File "sfx.7zip.tmp" or "sfx.7zip.tmp1" (when running more than one parallel) files are created in this location where the batch has been started (e.g Desktop).
Is that normal? In IA 18 the file has been created in the target directory...
Heiko
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: Question: sfx.7zip.tmp
Postby FrancescoT » Wed Sep 21, 2016 11:38 am
Dear Heiko,
I just tried with a batch file that has the following line;
- start "C:\Program Files (x86)\InstallAware X5" miabuild.exe "C:\Users\test\Documents\my project\My Project.mpr"
...and I am not able to see any "sfx.7zip.tmp" file left within the folder used to start the batch file (I also tried from the desktop dir).
For what I see, the unique "sfx.7zip.tmp" is the "temporary" one within the project release folder.
mikKummerfeld
Postby mikKummerfeld » Wed Sep 21, 2016 12:51 pm
I am using just miabuild without the path. I think the Application is found over Environment Variable "Path" which Contains the Installation folder of IA X5.
I have more Problems with miabuild but maybe this is the reason for everything. E.g Data folder still exists After Build in compression Mode (only miabuild, IDE Works Fine)
Kind regards
Heiko Kummerfeld
MIK GmbH
Postby FrancescoT » Wed Sep 21, 2016 1:11 pm
Dear Heiko,
contact me directly via email at; support@installaware.com.
I'll try to see if I have any chance to verify what you are reporting.
Users browsing this forum: No registered users and 149 guests
