Copy OR Move Commands
Hi
I Couldn't figure out what is wrong with my script.
After Apply Install, I have a Copy Command which is not working.
I have a text file in the Target Directory ( where my files are installed ),
which i am trying to copy to another directory.
Find below the two lines of my script.
~InstallAware Clipboard Data~
~Apply Changes~
~{25833FF8-2B73-414B-AEE2-DE3532A65C5D}~
~progress~
~SUCCESS~
~TRUE~
~FALSE~
~Copy/Move Local Files~
~{C7E6D95B-65F1-4CB4-B824-2C7B6C6CF4AD}~
~$TARGETDIR$~
~tips.txt~
~F:\InstDev~
~tips.txt~
~TRUE~
~FALSE|FALSE~
Apprecite your help.
SITL
~Apply Changes~
~progress~
~SUCCESS~
~TRUE~
~FALSE~
~$TARGETDIR$~
~tips.txt~
~F:\InstDev~
~tips.txt~
~TRUE~
~FALSE|FALSE~
SITL
Re: Copy OR Move Commands
SITL,
The copy/move command is in the (by default) purple command list and they get stacked/sequenced for execution but only get executed when Apply Install executes. Placing it after the Apply Install could explain why it isn't "working". Try placing it before the Apply Install command. Does that help?
Dear bokkie,
Appreciate your reply.
At the beginning of the installation, depending on license type i need to copy some files and rename.
Since that didn't work, i placed copy command after the Apply install.
I read about purple commands here in this forum. i put maximum effort to make it work before posting here,
My machine is Windows 7 with Admin rights.
Do you see any other problem in the below copy/move commands
~$TARGETDIR$~
~tips.txt~
~F:\InstDev~
~tips.txt~
~TRUE~
~FALSE|FALSE~
Thanks for the help
SITL
~$TARGETDIR$~
~tips.txt~
~F:\InstDev~
~tips.txt~
~TRUE~
~FALSE|FALSE~
Thanks for the help
SITL
I'll try and test your code later. To recap, then, you want to copy files at the beginning knowing you've done what you want to do prior to running the Apply Install. In that case, have you considered or tried using the native engine setting in the script? Enable it before you do the copy and disable it after. In case you might not have come across it before, the following link explains more about it:
http://www.installaware.com/FlashHelp/nativeengine.htm
Could you try it and see if resolves things for you?
Dear Bokkie,
Thanks for the reply,
I have my file packaged along with the installable's, which i want to copy/rename depending on license type.
So which Predefined variable i should use, SUPPORTDIR OR TARGETDIR ?
Which is the variable that refers to the directory which contains all the files to be installed ?
I have properly initialized SourcePath and DestPath and
After setting NATIVE_ENGINE to TRUE,
This one works :
~{B6AB4215-A7AF-49A1-BA87-15DA476070E8}~
~$SourcePath$~
~tips.txt~
~$DestPath$~
~tips.txt~
~TRUE~
~FALSE|FALSE~
This one doesn't work:
~{E5C68143-6AA4-4CA5-831F-3C880D8C11FF}~
~$SUPPORTDIR$~
~tips.txt~
~$DestPaht$~
~tips.txt~
~TRUE~
~FALSE|FALSE~
And this one also doesn't work:
~{A178FA43-9575-43CE-9A12-95C3F16CAC0C}~
~$TARGETDIR$~
~tips.txt~
~$DestPath$~
~tipsRenamed.txt~
~TRUE~
~FALSE|FALSE~
SITL
This one works :
~$SourcePath$~
~tips.txt~
~$DestPath$~
~tips.txt~
~TRUE~
~FALSE|FALSE~
~$SUPPORTDIR$~
~tips.txt~
~$DestPaht$~
~tips.txt~
~TRUE~
~FALSE|FALSE~
~$TARGETDIR$~
~tips.txt~
~$DestPath$~
~tipsRenamed.txt~
~TRUE~
~FALSE|FALSE~
SITL
Dear STL,
1 - Did you add your file into your project SUPPORTDIR?
http://www.installaware.com/forums/view ... DIR#p40674
2- Are you sure that you are copying/moving TARGETDIR files after APPLY INSTALL execution?
By default with an MSI based setup, Target files are only available once these are effectively installed!
Dear Francesco Toscano,
Great help, things are progressing
SUPPORTDIR related issue works, thanks.
However, One problem remains,
i.e., During installation we ask user to select the license file, that file we want to copy to TARGETDIR.
So here is the script, that is not working.
NOTE : Selection of license file is using Open File Dialog, And variables LicenseFilePath & LicenseFileName are properly initiated.
I'm watching these two variables.
~Set Variable~
~{F4B9D630-CA1C-44A4-9036-06D686BBE413}~
~NATIVE_ENGINE$MYAH$MYAH$FALSE~
~TRUE~
~{8852C1C1-8AED-411C-8DBC-A68190194277}~
~$LiccenseFilePath$~
~$LicenseFileName$~
~$TARGETDIR$~
~$LicenseFileName$~
~TRUE~
~FALSE|FALSE~
~Set Variable~
~{AFE947B0-44D1-4FF8-8D81-09946477C791}~
~FALSE~
With your help, thins are progressing, Appreciate,
Have a great day !
SITL
~Set Variable~
~TRUE~
~$LicenseFileName$~
~$TARGETDIR$~
~$LicenseFileName$~
~TRUE~
~FALSE|FALSE~
~Set Variable~
~FALSE~
Have a great day !
SITL
Dear SITL,
you should post at least a minimal project or alternatively you should describe in details, how those commands are exactly sequenced in your script.
I am very sorry, but just looking at your commands I am not able to understand when these get called and/or if the commands parameters are correct.
Sorry for inconvenience.
I have created a sample project and simplified to some extent.
Testing steps:
Once you extract files, I have a "Source" folder inside TestApp.
Source folder contains files to be installed and a file(TestV2C.v2c.) to be copied and renamed.
Please bear with me for few extra screens.
Click Next, Next until you hit License type screen (sorry, i could not simplify much, I'm still new to IA
In License type screen, Select License File i.e., TestV2C.v2c, Once you select, it move to next screen and complete the installation.
Installation is fine, but the TestV2C.v2c file is not copied to TARGETDIR.
Thanks for your help And I appreciate you response.
SITL
Testing steps:
SITL
- TestApp.rar
- (3.68 MiB) Downloaded 2161 times
Dear SITL,
of course your TestV2C.v2c file doesn't get stored under TARGETDIR.
You missed to consider that TARGETDIR will only exist on the target machine after APPLY INSTALL execution.
So to solve your problem, just move your COPY/MOVE file operation immediately after the APPLY INSTALL statement in your main script.
For example;
For example;
if Variable SUCCESS Equals COMPLETE
Copy Local Files $LiccenseFilePath$\$LicenseFileName$ to $TARGETDIR$\$LicenseFileName$
Thanks for your reply.
First I tried placing after Apply Install, It didn't work, then this is what Bokkie told me to do . . .
Bokkie -
Actually, I tried both the ways.
Have a great day !
SITL.
Bokkie -
Have a great day !
SITL.
SITL,
I, like Francesco, am also puzzled with your problem. I have never had a problem using Copy/Move. Can I ask you to try something? Can you put some message boxes in your code and display the value of all the variables you reference in your Copy/Move statement and tell us what the directory and filenames are?
Referring to Francesco's code snippet can you also display the value of the Apply Install's SUCCESS variable as well? We need to make sure the "if" statement is being executed and not running around it.
I'm just thinking aloud here but are you certain there are no access restrictions with the files you want to copy?
I don't know if we've discussed this but when your installation completes can you open a DOS command prompt and see if you can manually copy the file?
Dear Bokkie,
Appreciate your quick response.
You spotted the problem, It was access denied.
It's working fine now.
Thank you, Bokkie and Francesco T
SITL
SITL
Delighted to read it's working okay for you now.
