Installware does'nt Install the new files but it does delete.
alfrqan
Post by alfrqan »
hello
My Installer doesn't Install the new files but it does delete.Since i used some delete commands on my project beyond install commands.
I don't know exactly what is the problem.if you do need from me to include the installer (Project) ,it is too big to be uploaded.
Regards, Nasr
Re: Installware does'nt Install the new files but it does delete.
Dear Nasr,
without having a clear picture of what your installer does, it's quite impossible for me to try to isolate the cause of the issue.
You may try to send me a very minimal copy of your project. At this purpose, It may be enough to receive just your project files (the IA project folder) ...probably the problem is due your script logic.
Eventually, you can send them as compressed archive format to; [email protected].
