Custom Component/Feature Form
donbrookes
Postby donbrookes » Wed Nov 16, 2016 8:18 am
Just wanted to verify something. I want to create my own custom component/Feature custom form. I want to use check boxes instead of the tree control that is provided. I have modified the form to have the desired set of check boxes and now I need to write the script. I was going to use Get Component State and Set Component State to translate with the check boxes. Does this sound right?
Re: Custom Component/Feature Form
Postby FrancescoT » Wed Nov 16, 2016 12:23 pm
Dear Donbrookes,
yes, you are correct. "Get\Set Component State" are the only methods that can be used at such purpose.
donbrookes
Postby donbrookes » Wed Nov 16, 2016 1:52 pm
It worked great, thanks ! :D
Postby FrancescoT » Wed Nov 16, 2016 1:57 pm
:D
Users browsing this forum: No registered users and 57 guests
