X5 not showing filenames in progresstext
rev23dev
Post by rev23dev »
After updating my project to X5 I noticed that the progress text no longer formats itself properly and just has the place holders for things where filenames are supposed to go. See attachment.
Was able to reproduce this with a brand new .NET Setup as well.
Re: X5 not showing filenames in progresstext
Dear Rev23dev,
I just tried to rebuild an old project using IA X5 and I don't see any problem.
By the way and when running a MSI based setup, all the progress texts displayed are just those generated by the MSI Engine directly.
rev23dev
Post by rev23dev »
So I ran the same setup in a VM and it worked fine. The difference? This PC is on Windows 10 Insider (Fast Ring) so currently on build 14965. So, could be a Windows bug, or may be something IA needs to update for the next version of Windows 10 coming in a couple of months?
rev23dev
Post by rev23dev »
Yep, just watched another MSI that isn't even mine do it, too. It does not appear to be built by InstallAware so I think you're off the hook! :P
:D
rev23dev
Post by rev23dev »
Just a heads up, Microsoft is getting super close to releasing this version of Windows 10 and its still an issue that they seem to have little interest in fixing.
Just wanted to let you know in case this is something they've changed in MSI or something that you as installer vendors need to be aware of that they're failing to communicate to you :)
JonPerkins
Post by JonPerkins »
I'm running the final (so Microsoft say!) build of the Creators Update of Windows 10 - set for more general release on April 11- and the issue is still present. It must be down to some internal change that Microsoft made to an API call, which they are certainly prone to do (finding an anti-virus product that runs well with Windows Insider previews is virtually impossible).
Despite that, great work everybody. Excellent product! :D
safepage
Post by safepage »
Has this been fixed in the latest release?
JonPerkins
No, but I don't think it's actually a fault with Installaware. I read on a different thread (on this site) that the messages which are displayed are received directly from the Windows Installer subsystem, so it's not that IA is failing to make a correct text substitution. I still see the filename placeholders (e.g. Copying [%1]...) on my dev PC (which is a standard W10 Creators Update 1703), but as I attempt the same setup program on my laptop as I write this reply (which is running the latest preview of W10 1709 - Creators Update Fall edition) the text is correct again. I only issue a new setup about once every nine months so I do not have a clearer picture - others will also need to comment to give us more info.
In fact! it's a Windows Installer Engine issue and it affects some WIN 10 versions.
amolago
Post by amolago »
Apparently this has been seen in WiX too (https://stackoverflow.com/questions/441 ... ing-instal), and those that use WiX can fix it or at least work around it?
So is there something IA can/will do, or are we stuck waiting for MS to sort it out?
Bjarne
Post by Bjarne »
FrancescoT wrote:In fact! it's a Windows Installer Engine issue and it affects some WIN 10 versions.
Thanks for this info, I've been wondering myself whats going on :mrgreen:
/Bjarne
mdavtec
Post by mdavtec »
We are seeing same issue on Windows 10. Any fix for this?
ExchA
amolago
Post by amolago »
Hiya,
Just chasing up some old problems... was there any updates/fixes on this? Either from IA or MS?
