List of Bug Fixes in InstallAware X5 update 22.01
* "Include Script - Return from Include Script with result": Fixed discrepancies between the command line/automation interface build vs. the IDE build.
* "ShellList dialog control": fixed a problem that caused the setup package to fail when executed under system account.
* Fixed some minor problems with the Visual Studio Add-In registration.
* InstallAware IDE: the Ctrl+A selection caused the incorrect display of About window. CTRL+SHIFT+A is the new key binding for the About window.
IMPORTANT!
Due the fixes to the command line build and automation interface, a full reinstall is recommended.
Use a new re-generated personal license file to activate this product update.
December 06, 2016
