Application Maintenance dialog caption
SITL
Postby SITL » Mon Dec 19, 2016 5:39 am
Dear Francesco,
I migrated from IA X4 to IA X5
I am changing Caption of Application maintenance dialog and
few controls in that like Modify, Remove, uninstall and adding few images.
I saved, And test it using Tools/Test dialog. everything looks fine.
But when i build, install and again install it comes to application maintenance dialog,
the images are fine but not the caption.
Surprised, I did clean the output directory manually.
I verified the date-time stamp of .dfm file in the project directory, but it is not showing the
latest date. where do you cache ?. worried :evil:
The .dfm file is not showing the latest modified date-time :?:
I have done this kind of changes everywhere using IA X4,
changes used to reflect properly after the build.
Then i changed some caption in other screens as well, same problem.
Appreciate your support.
Please advice.
SITL
Re: Application Maintenance dialog caption
Postby FrancescoT » Mon Dec 19, 2016 12:50 pm
Dear SITL,
the Dialog Editor doesn't store or use any cache ...I suggest you to verify where you are effectively saving your dialog files.
SITL
Postby SITL » Tue Dec 20, 2016 1:30 am
Dear Francesco,
Thanks for your reply.
Sorry to say,but please look at my comments.
Nobody can complain about such a basic thing.
I have spend sufficient time.This could be the BIGGEST discouraging factor about InstrallAware.
Please verify.
SITL
Postby FrancescoT » Tue Dec 20, 2016 5:59 am
Dear SITL,
honestly, I can only suppose that there is something wrong with the approach you used...I am not able to see any problem.
If you have any chance to post a very VERY minimal project, along with the exact steps required to replicate the issue, I'll be happy to verify it.
SITL
Postby SITL » Tue Dec 20, 2016 7:25 am
Dear Francesco,
Thanks for your comment. I understand !
I did all kind of testing.
Due to time factor, I have to move on...
We'll revisit later.
Points form previous posting :
What happens when i build and install ?
SITL
SITL
Postby SITL » Thu Dec 22, 2016 6:53 am
Dear Francisco,
For your info...
We have licensed version of IA X5.
But I have installed trial version of IA X5 on my development machine and not applied license.
Does this cause any trouble ?
SITL
Postby FrancescoT » Thu Dec 22, 2016 10:21 am
Dear SITL,
the trial doesn't have any limitation in terms of features or usability. The only limitation is with the generated package which displays a demo warning.
