When i choose the Application runtimes (Microsoft Visual C++ runtime for 2015), while installing it says system re-boot required.
Can we give the option of re-boot later? as currenlty it requires a madate re-boot for the runtime
Microsoft Visual c++ Runtime for 2015 requires reboot
kishorkk23
Re: Microsoft Visual c++ Runtime for 2015 requires reboot
Dear kishorkk23,
the IA VC++ install script (eg. "setupvc14rtm_update1_x86.mia" or "setupvc14rtm_update1_x64.mia") already implements the /norestart command line option to install the Microsoft Visual C++ 14 (Visual Studio 2015).
So in your case, you could modify the default script code in order to temporary ignore and skip such restart request. By default the install script use a "Reboot Computer and Resume Setup" command, when the visual C++ installer returns "3010" or "23" as result value.
At any rate, please consider that in case you are also installing other components that require the presence of VC++ RTM, these may fail to install due the skipped system reboot.
Finally and if you decide to proceed in this way, don't forget to programatically ask for a system reboot at the of your installation and in case the previous reboot request has been effectively skipped.
kishorkk23
Thanks, where in the script can i provide this option of re-boot later?
Currently it shows Cancel or ok to re-boot
Dear kishorkk23,
as I have already said, you should modify the default script code in order to temporary ignore and skip such restart request. "By default the install script use a "Reboot Computer and Resume Setup" command, when the visual C++ installer returns "3010" or "23" as result value."
You may use a custom variable to store the skipped re-boot condition and at the end of your setup process, you may conditionally reboot the system.
