tray icon does not apper in windows 10
kishorkk23
Post by kishorkk23 »
In my install, windows 10 tray does not show the tool icon. But the same is shown in the windows 7 and windows8.
We are using IA x5 to build the project.
Attached are the snapshots. How can we fix this ?
kishorkk23
Re: tray icon does not apper in windows 10
Is there any help on this?
Dear kishorkk23,
it's not clear if you are referring to the icon displayed while running the installer or the taskbar icon of your app once installed.
In case it's the application taskbar icon, I suggest you to have a look at the "Shortcuts sample" from;
viewtopic.php?f=2&t=6772
