SUGGESTIONS
JXBURNS
SUGGESTIONS
Post by JXBURNS »
1) Could we have a function (right mouse click - popup menu) that will allow INSERT VARIABLE and then provides a list of built-in and user defined variables (so far)? It is a pain trying to remember name of variables and often my installer fails because I have missed off the dollar sign or misspelled it.
2) The REPLACE function is very unwieldy. After entering from/to values, click FIND NEXT until you find the line you want. Then click REPLACE. It ignores the line you are on and jumps to the first line containing the FROM word. Could it not assume the user knows which line they want to start from having clicked FIND NEXT, and not expect them to go back to the start again?
3) GPO Wizard. Have the source compressed and MSI filenames default to the last file created to save having to search/enter details.
4) Remove CTRL-A as shortcut for the About box but allow it to select all the script lines instead (as in default Windows behaviour).
5) Add shortcut keys to MOVE UP & DOWN in scripts to save having to click on line, right mouse click and then select option.
6) Add a category to this forum for next version suggestions.
Thanks - John
Thanks for your suggestions, John.
The move up-down shortcut is already available - CTRL+ up arrow/down arrow.
