Shortcut problem
mikKummerfeld
Shortcut problem
Post by mikKummerfeld »
Hello Guys,
i have problems with the icon file path in my shortcuts for batch files.
My targetdir variable is not targetdir, it is $TARGETDIRCLIENT$ and $TARGETDIRSERVER$.
The icon is blank/empty wenn I use the path to the ico file:
"$TARGETDIRCLIENT$\bin\delta_32x32.ico"
i am using native_engine
What can I do?
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Re: Shortcut problem
Dear MikKummerfeld,
I just tried to verify what your reported, but honestly, I don't see any problem with the assigned shortcut icon.
I used a Native Engine IA X5 project, installed the icon file to the TARGETDIR and then assigned it to the "Icon File" parameter of the "Create Shortcut" command.
For the icon file I used a multiformat icon file and which includes all the different image formats from, 16x16 to 256x256.
mikKummerfeld
Hi Francesco,
I install the .ico file in the TARGETDIRCLIENT path and after that I use "$TARGETDIRCLIENT$\shortcut.ico" but it does not work :(
The ico file is available in the destination folder but the Shortcut has a White blank icon :(
I cant understand...
Heiko
Kind regards
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
as I said previous previously, are you sure about the correct format of your icon file?
mikKummerfeld
Yes it is correct. We now convert the batches to exe with the icons and now its fine
Workaround
Kind regards
Heiko Kummerfeld
MIK GmbH
