Is it possible to pass data via a command line parameter?
My installer requires the end user to supply some data, and whilst I have created some custome dialog pages to capture this, for some implementations I would like the deployment to be possible using the MSI and a /silent command line switch.
This means that I either need to specify some default values within the installer which will need to be modified post installation, or allow the end users to supply data via command line parameters, eg.
setup.msi /location C:\Whatever /server 172.0.0.1
