Hi.
I have a dialog which has 2 radiobuttons .... names of A and B for example
Within my script, before calling the dialog, I have information which determines whether the "checked" property should be set on field A or on field B. i.e. I want to force a different default to be checked based on information they provided earlier.
How can I make that happen before calling the dialog.
George
How to control a dialogs radiobuttons checked property from script
wxperson99
Re: How to control a dialogs radiobuttons checked property from script
Dear Wxperson99,
please have a look at the following link.
viewtopic.php?f=2&t=6072
In addition for a sample, you may also have a look at how Radio Buttons are controlled with some of the standard setup dialogs
...eg., "SetupType", "StartMenu" or "Maintenance" dialogs.
wxperson99
How do I set A's associated checked variable to True... assuming the dialog name is setuptype?
In my case A's name is "Complete"... so is there some kind of variable called setuptype.Complete.checked that can be set to true?
i.e. dialogname.object.property ?
George
George
wxperson99
I now see the object rules section. Let me play with that to see if I can do what I want.
