Accessing files in %windir%\system32 folder from 32-bit MSI
mdavtec
Post by mdavtec »
My MSI file is build as 32-bit and I want to file version of a DLL in %windir%\system32 folder. I tried using "Set 64 Bit Mode" command and then use $WINSYSDIR$ folder.
~InstallAware Clipboard Data~
~Get File Version~
~{0A88D5B9-6674-4960-98DA-5FEEB9B462CE}~
~$WINSYSDIR$\FOO.dll~
~DLLFileVersion~
~Set 64 Bit Mode~
~{36CB7CDA-B4B1-41B1-81D5-0C2A281D67CF}~
~FALSE~
~FALSE~
~TRUE~
But this is now working. It still get file version of DLL in SysWow64 folder. Any suggestion what can I do here? Also if I want to revert back to original mode, i.e. undo Set 64 bit mode, how would I do that.
I see following Warning in your online help fo "Set 64 bit Mode".
When applications are running on 64 bit Windows in 32 bit compatibility mode, Windows redirects file system and registry access to alternate 32 bit compatibility locations. This may cause undesired behavior with your setup if you call the Set 64 Bit Mode command after other commands that access the file system and registry.
Is that the reason, I'm not able to access file in System32.
ExchA
Re: Accessing files in %windir%\system32 folder from 32-bit MSI
Dear Mdavtec,
you should instead;
Set Variable FILE_VERSION to
Set Variable WINSYSDIR_X64 to
Get Folder Location System->System Directory into WINSYSDIR_X64
Get File Version $WINSYSDIR_X64$\FOO.dll into Variable FILE_VERSION
~Set 64 Bit Mode~
~{3C376276-B816-4D0C-967F-3EB452474B37}~
~TRUE~
~FALSE~
~FALSE~
~Get File Version~
~{C6CF712A-6EDA-430C-9BAD-D09A6B24A2DC}~
~$WINSYSDIR_X64$\FOO.dll~
~FILE_VERSION~
~Get Folder Location~
~{C57664B0-24CD-4A93-AD2D-41A16D3CB0B8}~
~WINSYSDIR_X64~
~23~
~FALSE~
~Set 64 Bit Mode~
~{C4B0AC1B-0488-4FAC-9D70-DDB44965AC47}~
~FALSE~
~FALSE~
~TRUE~
~Set Variable~
~{2505D5F8-0F86-4A10-8E86-A65F5EC8B080}~
~WINSYSDIR_X64$MYAH$MYAH$FALSE~
~Set Variable~
~{7929DAD6-89AE-415D-8F7F-01C9753FAB99}~
~FILE_VERSION$MYAH$MYAH$FALSE~
mdavtec
Post by mdavtec »
Thanks for the reply. That was helpful in resolving the issue.
I'm, in general, curious about this 32-bit or 64-bit installation. Does InstallAware has any documentation giving details and providing guidelines to users. Some of the questions I've,
- Can I use 32-bit installation program to install 64-bit application?
- What user should do if application is supported on both, x86 and x64, platform?
ExchA
Dear Mdavtec,
these should reply your questions.
viewtopic.php?f=2&t=8492
viewtopic.php?f=2&t=9966
