In Hardware Requirements I can select Memory up to 2GB.
As we need to Interface with a big Chromatography Data System our requirements are 4GB.
How can this be implemented?
Minimum Memory Requirement 4GB
Re: Minimum Memory Requirement 4GB
Dear Horst,
unfortunately this is not currently possible via "Get System Settings" command.
You may release an EXE or a DLL that at such purpose and then to execute it from your script.
It might be helpful to make the "Get System Settings" function a Little more flexible in a future Version. Thus one would not depend on the pre-defined configurations as currently.
Anyway for now I will be happy to follow the route of a DLL or keep it as is now, just displaying requirements text.
Dear Horst,
I was wrong on this and even on your other question (https://www.installaware.com/forums/viewtopic.php?f=2&t=10883).
You may use the "Total RAM Count (MB)" with the "Get System Settings" command.
Users browsing this forum: No registered users and 237 guests
