Get Exact OS Level into
SebSpiers
Post by SebSpiers »
Hi There,
I am using the "Get Exact OS Level into" function and was expecting to have a version number, eg: 10.0.14393
However when do this on a Windows 10 Home PC I get "TENTHREE" returned into the variable, it should return "10.0.14393".
I am confused?!?!
I'm not a developer, I just want to install things...
Re: Get Exact OS Level into
Dear SebSpiers,
if you have a look at the IA documentation about the command, you will see that the returned values are;
Consequently, "TENTHREE" is returned whe the target system is a "Windows 10 Redstone" (anniversary update - build 1607 - version 10.0.14393).
mihai
Post by mihai »
Hi Francesco,
Can you please confirm that TENTHREE / "Windows 10 Redstone" still refers to 1607 / "Redstone 1" / "Anniversary Update" in InstallAware X6?
Get Exact Operating System Version.png (18.45 KiB) Viewed 4792 times
I'm interested because that's the minimum Windows 10 that supports .NET Framework 4.8. Here's the full list from wikipedia, to match against:
From wikipedia
From wikipedia
Windows 10 Versions and Codenames.png (20.04 KiB) Viewed 4792 times
Yes! TENTHREE = "Windows 10 Anniversary Update v.1607"
