Cache setup source
SITL
Cache setup source
Post by SITL »
Dear Francisco,
Thanks for all the support, Great !
I have few Questions.
1. How do specify the directory for caching setup sources ?
We want to keep it in a specified directory, say C:\XYZInstallerCache
2. How to detect the path of Excel.exe ?
Means how to find where excel is installed ?
3. In the Maintenance dialog, We want to Select appropriate Radio button.
( Modify, Remove & Repair)
For example, If the product is installed, we want to select Remove button by default.
Appreciate your help.
SITL
Re: Cache setup source
Dear SITL,
1- you may use the OVERRIDECACHE pre-defined script variable for that.
viewtopic.php?f=2&t=10651&p=40781&hilit ... CHE#p40560
2- you should post this question on a Microsoft forum or to have a look at the Excel documentation. I suppose the Excel installer defines some Registry Key on the target machine to keep track of the installed application. However, I am not an Excel expert.
3- please have look at the following link.
viewtopic.php?f=2&t=10863&hilit=Radio
mikKummerfeld
Post by mikKummerfeld »
HI SITL,
I already have a Excel find script - I search and post it
Heiko
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
SITL
Post by SITL »
Dear Francisco,
Thanks for your help.
Regarding my second question, Excel, I'm using Read Registry key and getting the path, Fine no issues here.
But there is some permission issue, Actually I want to copy a file there :wink: I'm not able to do so.
We have some template.xla file to be copied to the path where MS Excel is installed.
I will try this :)
Very happy for your support.
SITL
SITL
Post by SITL »
Dear Francesco,
In Design\User Interface\EULA and Readme we have an option to load the license agreement text from .rtf or .txt file.
I have saved my license agreement from .rtf file, but the problem is some lines were in BOLD, All the bold words are shown as regular text.
How do we display bold characters in licesnse agreement?
SITL
Dear SITl,
honestly I don't see that problem...I just imported a RTF document into an IA project.
SITL
Post by SITL »
thanks,
I cleared EULA and again loaded from .rtf
it works.
SITL
SITL
Post by SITL »
SITL wrote:Dear Francisco,
I will try this :)
SITL
Dear Francesco,
I'm NOT able to copy a file to the path where MS Excel is installed.
I have to copy one template file there. Is this allowed ?
Do you have any idea ?
Please share your thoughts.
SITL
Dear SITL,
you may use the "Set Access Control" to change your target folder permissions.
viewtopic.php?f=2&t=10724
SITL
Post by SITL »
Dear Francesco,
Hey...I'm surprised to see that Read registry key command returns TRUE or FALSE.
~InstallAware Clipboard Data~
~Read Registry~
~{7BA5D7C2-AFEE-40A8-AED0-F00B29B108B4}~
~INSTALLED_EXCEL|~
~2~
~SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\excel.exe~
~Path~
Is there a way to get the installed path ?
SITL
Dear SITL,
I don't have an Excell installation that can be used to test your "Read Registry" call.
However, I just used the following one to get the path of Acrobat Reader v.10 ... and this returns the Path value as expected.
~Read Registry~
~{506527A3-FCF5-437A-AAB9-F7F8130246EF}~
~ACRO_PATH|~
~2~
~SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\AcroRd32.exe~
~Path~
~Set Variable~
~{BE4A979B-FC94-45F8-9CD8-E27DE1EFA869}~
~ACRO_PATH$MYAH$MYAH$FALSE~
NOTE!
By default on a X64 OS, the above code will return the value stored under the "Wow6432Node" of the HKLM\SOFTWARE root.
viewtopic.php?f=2&t=10339
!!!IMPORTANT!!!
Please start new topics where appropriate, rather than adding new questions to a thread originally started for a different discussion.
Thanks!
SITL
Post by SITL »
Sorry, I understand !
- SITL
