Hello Support,
we received our new GlobalSign CodeSigning Certificate and we need a token on USB dongle to use it.
How can I use the Setup Authentication as we do not have pfx and p12 file and we can not export the cert with private key information.
We can just export a cert file but I can not use it with IA
Heiko
MIK
Signing Setups with USB Dongle
mikKummerfeld
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
Re: Signing Setups with USB Dongle
Dear Heiko,
unfortunately, currently there is no way of using USB dongle with the Authentication settings.
At the moment, I cannot anticipate if/when such capability will be implemented in future versions.
mikKummerfeld
And how can I sign our setups now?
Kind regards
Heiko Kummerfeld
MIK GmbH
Heiko Kummerfeld
MIK GmbH
Dear Heiko,
I suppose this the only approach that can be used;
https://support.globalsign.com/customer ... es/1698751
For what I understand, you may use IA build Events to integrate the approach described by the link.
mikKummerfeld
We now use a pfx file again from digicert - Solved
Kind regards
Heiko Kummerfeld
MIK GmbH
Heiko Kummerfeld
MIK GmbH
