Using Text-DFMs?
stebi
Using Text-DFMs?
Postby stebi » Mon Jul 31, 2006 5:25 am
is it possible to save the Dialog-DFMs as Text? It's much better for version control if they are not saved as binary. IA doesn't accept them when I can convert them (with Borland Delphis "convert.exe"). It always says "invalid stream format".
Postby MichaelNesmith » Mon Jul 31, 2006 6:10 am
You can try converting them back to binary!
stebi
Postby stebi » Mon Jul 31, 2006 6:53 am
Converting back is no problem. It was only a try to see if IA can handle text dfms. My question was, if it is possible to use text dfms with IA? I think it would be an improvement because everybody uses a version control system (if not they should think about it!).
Postby MichaelNesmith » Mon Jul 31, 2006 4:18 pm
Thanks for the suggestion, I've entered it into the wish list for you.
Users browsing this forum: Google [Bot] and 86 guests
