Hello Support,
in our current MSI package we have 4 components. How can I active/deactive each of them at silent installations using CMDLINE ?
E.g
component one
component two
component three
component four
I only want to install "component one" and "component three".
Heiko
CMDLINE & COMPONENTS
mikKummerfeld
Kind regards
Heiko Kummerfeld
MIK GmbH
Head of quality assurance
technical consultant
Heiko Kummerfeld
MIK GmbH
Re: CMDLINE & COMPONENTS
Dear Heiko,
this is quite simple.
At very beginning of the "Perform First Time or Maintenance Installation" code-region of your main script file, you may use the "Set Component State" command, to conditionally set the state of component based on the value of a custom script variable. Then the same variable can be passed from command line.
