Dear Francesco,
Can you please tell me the correct use of Until command ?
Sorry for very basic question.
SITL
Until command
Re: Until command
Dear SITL,
this is really simple;
Set Variable Count to 0
repeat
MessageBox: Repeat test, Count = $Count$
Count = $Count$ + 1
until Variable Count Greater Than 5
MessageBox: Repeat test, Completed
The Until command is used to end a loop after performing an evaluation. The loop ended using this command must have been started using the Repeat command. If the evaluation is unsuccessful, one more iteration of the loop will be executed. Upon the ending of each iteration, the loop condition will be re-evaluated, and the loop re-executed until the conditional succeeds.
Users browsing this forum: No registered users and 85 guests
