Clean MSI database
SITL
Clean MSI database
Postby SITL » Wed Apr 26, 2017 3:30 am
Dear Francesco,
Thanks for your help.
Is there a way i can refresh MSI database for my project ?.
I mean clear all object references & rebuild my project.
Some of the issues are hard to comprehend.
Since i have not made any changes, clean build may solve the issues.
(I have couple of issues like silent install not working, shortcut image is not shown etc.,)
The issues are show stoppers, please help.
Appreciate your advice.
SITL
Re: Clean MSI database
Postby FrancescoT » Wed Apr 26, 2017 11:22 am
Dear SITL,
the MSI database gets created from scratch each time the project is built. So there isn't any MSI db to clean.
You may eventually need to work on a new project or to fix the possible errors that may exist with your scripts.
SITL
Postby SITL » Thu Apr 27, 2017 12:45 am
Francesco,
Thanks for your advice,
Yaa.., It's better to create a new project :)
Suppose i create a new project, Is there any guide lines to replace files from older project to new project ?
I have to methodically copy files from older project.
I think except .mpr all the files can be replaced :? .... I'll try that.
SITL
Postby FrancescoT » Thu Apr 27, 2017 11:59 am
Dear SITL,
I'm not quite sure to which files you are referring. If these are script files, just move them into the new project folder and then selectively select to import them.
SITL
Postby SITL » Fri Apr 28, 2017 4:40 am
I regularly take backup of my project,
I just taken latest project from the backup & No issues. :D
Happy week end.
Bye
SITL
Users browsing this forum: No registered users and 93 guests
