Dear Francesco,
Thanks for all the help.
This is regarding Uninstall problem after applying patch.
Both Base project & Patch is working fine on the development machine.(Win 7, 64 bit )
Our QA team has reported one issue regarding Un-Installation.
This isssue is on Windows 10 machines.
My base project is working as expected, both installation and Un-Installation is fine.
However, after applying patch files in the installed folder & shortcuts remains intact but registry cleanup is happening.
(Patch is created with Manual mode)
Question:
After Apply Uninstall, If SUCCESS equals COMPLETE,
Can i use Delete Files (*.*) from TARGETDIR ?
what is the proper way to delete sub folders ?
Appreciate your advice / hints .
Thanks & Regards
SITL
Uninstall issue
Re: Uninstall issue
Dear SITL,
as already discussed with you several times, I suggest you once again, to compare your Base/Patch projects and code, with those included with the Patch sample. If you have chance to verify the sample, you will see that everything gets removed on UnInstall.
https://www.installaware.com/forums/viewtopic.php?f=2&t=8697
You can use the "Delete Files Recursive" (to delete all matching files in subfolders as well) or " Delete Files ", in combination with the "RemoveDirectory" WinApi to delete the root folder.
https://www.installaware.com/forums/viewtopic.php?f=2&t=10457
For more details about the above commands, please consult the IA documentation. For more details about "RemoveDirectory" WinApi, please consult the official Microsoft documentation.
Users browsing this forum: No registered users and 103 guests
