the specified account already exists error
premjeet.singh
Postby premjeet.singh » Thu Jul 06, 2017 6:27 am
I am using Installaware 18. I have a master installer with single child installer(.msi). When master installer starts installation with child installer, the popup(message box) appears saying that "the specified account already exists". Then after clicking on "OK" button again popup appears saying that "Fatal error during installation".Then again after clicking on "OK" button the setup exits.
Please reply it as soon as possible.
Re: the specified account already exists error
Postby FrancescoT » Thu Jul 06, 2017 1:19 pm
unfortunately, without knowing what your script logic does, it quite difficult to say something about the issue you seem to have.
If you have a chance to send me a VERY MINIMAL PROJECT that replicates the issue (...in your case these should be two projects), I'll try to have a look.
frank may
Postby frank may » Fri Nov 30, 2018 4:13 pm
I am having a very similar issue when launching a small second install.
The code for my second install is as below. It basically reads a value from a text file and then writes a shortcut to the windows/installer directory. This small install forces an admin user login.
Can you give me some direction as to what may be going wrong?
Frank
Get Common Folder Location System->Windows Directory into WINDOWSINSTALLERDIR
Set Variable WINDOWSINSTALLERDIR to $WINDOWSINSTALLERDIR$\Installer
if Variable REMOVE Equals TRUE
Comment: Uninstall product
Apply Uninstall (get result into variable SUCCESS)
Set Variable PROGRESS to 100
else
Set Persistent Variable UPDATEEXE to
Set Persistent Variable LOCALAPPDRIVE to
Get Folder Location Other->Local Application Data into LOCALAPPDRIVE
Extract Parent Drive: LOCALAPPDRIVE
Read from Text File $LOCALAPPDRIVE$USERS\PUBLIC\PCUPDATE.TXT into Variable UPDATEEXE
Create Shortcut $WINDOWSINSTALLERDIR$\#TITLE# Updates to $UPDATEEXE$
Write into Text File $LOCALAPPDRIVE$USERS\PUBLIC\output.txt from Value UPDATEEXE = $UPDATEEXE$ (at end of file)
Write into Text File $LOCALAPPDRIVE$USERS\PUBLIC\output.txt from Value WINDOWSINSTALLERDIR = $WINDOWSINSTALLERDIR$ (at end of file)
Write into Text File $LOCALAPPDRIVE$USERS\PUBLIC\output.txt from Value #TITLE# Updates (at end of file)
Users browsing this forum: No registered users and 249 guests
