Hi Everybody,
I have 57 files changed in the second patch.
Both Patch1 & Patch 2 are applied successfully.
Since we did not get any error, we did not verify all the files.
At some point we figured out that one help file (.chm), which was supposed to get updated
through Patch2 was not updated.
I recreated patch2 & did all possible checks, no success yet.
(Dear Francesco, If possible, please advice me on this topic)
Appreciate your help.
SITL
Problem with Second patch
Re: Problem with Second patch
Dear SITL,
I suggest you to have a look at steps described with the following link;
http://www.installaware.com/forum/viewt ... 582#p35582
(see my reply dated "Thu Aug 01, 2013 11:53 am " about " Power Tweaks").
Last but not least, patches have to be used for very minimal update ONLY. A package which updates 57 files cannot be considered a minimal update. This is a new version release instead.
