I'm trying to upgrade our installer to X6. Although the project loads and builds without issue, when I try to run the resulting installer (a single file with good compression) the installer unpacks but quits saying it needs Windows 8 minimum. This is not true, our software runs just fine on Windows 7. I have tried turning off the OS check altogether but the problem persists.
I presume installers built with IA X6 can be run on Windows 7?
Installers generated with X6 need Windows 8 minimum?
Re: Installers generated with X6 need Windows 8 minimum?
I've answered my own question. My installer included SQL Server 2016 which is not compatible with Windows 7, only Windows 8 and above. This is the reason why the installer would not run.
