Runtimes and x64
koxo
Runtimes and x64
Post by koxo »
I have create a projet for x64. (on IW X6)
All is OK.
Now if add a x64 runtime (example : Microsoft Visual C++ 12.0... x64)
When i execute the installation the default path for installation is C:\Program File (x86)\MyApp
If i remove the runtime, the default path is good : C:\Program File\MyApp
If a try the debug ... the line Get Folder Location -> Program Files Directory into PROGRAMFILES return the bad value if i use a x64 runtime.
Thank you
KoXo
koxo
Re: Runtimes and x64
Post by koxo »
If i make a blank project with no files, it seems to be ok ...
Strange .....
How the variable PROGRAMFILES is solved ?
