I am using the latest build of Express.
I need for the install to close Outlook before it runs. Can/how do I do this?
Even if it just pops up a reminder to shut it down that would be great.
Paula
Close Open Programs
There is no build in function for that (to terminate), but using Windows API you can do it. Check if the process is running by using the Check Process command and if it does, popup the warning using the MessageBalloon command of InstallAWARE.
If it's too advanced for your knownledge, i can do it for you at a very reasonable fee (not only this, but create the whole project).
Let me know by pm or at pkefal (at) installaware (dot) com
Panagiotis Kefalidis
Software Design Team Lead
Actually, i've created the script for you.. Please find it attached.
Use the Include Script command to use it in your installation file.
checkterminateprocess.mia
Re: Close Open Programs
Looks like the link is no longer available, anyway this can be revived?
Yes it is not.
I just replied your other post ... I suppose you can do it.
http://www.installaware.com/forum/viewt ... 000#p35000
