EV Authenticode Signing
Obliterator
Post by Obliterator »
It would be nice if your code signing improved to use named certificates installed on the machine (instead of given pfx files) and gave more control over the code signing parameters (for example /a /n /td /fd /d /du parameters).
For example, we currently sign our binaries as follows:
"C:\Program Files (x86)\Windows Kits\10\bin\x64\signtool.exe" sign /a /n "Our EV Cert Name" /tr http://timestamp.digicert.com /td sha256 /fd sha256 /d "App Signing Description" /du "App Signing Detail" "TargetFile.exe"
It would be great if IA Authenticode page allowed all of those parameters to be configured and passed them through. Or let us specify the signing command line to be executed and substituted "TargetFile.exe" with a variable.
rev23dev
Re: EV Authenticode Signing
Post by rev23dev »
I just got an EV cert and ran into this too. No one from IA even replied here.
Currently, it's not possible to specify an EV certificate from Authenticode settings.
However, it's Always possible to sign using an EV certificate via Build Events.
This is an example we released a while ago when Microsoft introduced "the New Code Signing Policy" ...there is just to update the signtool.exe parameters accordingly.
https://www.installaware.com/blog/?p=416
Finally, EV certificate support should be probably available with the next major release.
