Check Process and Terminate it if it's running
A small script to check if a process is running and terminate it.
If the process is found running, a messagebox is popuped prompting the user to terminate it.
You can change the PROCESS_NAME and PROGRAM_TITLE variables to fit any kind of processes.Now it's using OUTLOOK.exe as an example.
Any feedback welcome.
checkterminateprocess.mia
Panagiotis Kefalidis
Software Design Team Lead
thank's a lot for this script, i change PROCESS_NAME and PROGRAM_TITLE but it don't work in windows vista
Set Variable MSGBOX to
Set Variable PROGRAM_TITLE to WinZip Executable
Set Persistent Variable PROCESS_NAME to WZQKPICK.EXE
Check for Process "$PROCESS_NAME$", get result into variable RUNNING
if Variable RUNNING Equals TRUE
MessageBox: Terminate Process, The process $PROCESS_NAME$ is running and it will be terminated in order to continue the installation.$NEWLINE$Please save your work and then click OK.$NEWLINE$Click Cancel if you want to continue without terminating the process.
if Variable MSGBOX Equals OK
Terminate Program $PROGRAM_TITLE$
Maybe its some Vista security issue, did you test on other operating systems?
Terminate Process
I've been able to terminate programs fine on Vista, but haven't tried WinZip Quick Pick. Might want to make sure the title is exact - or try this way...
http://forums.installaware.com/viewtopic.php?t=1344
Haven't tried just using the Class Name without a caption, or even if IA will let you do it.
Re: Terminate Process
SteveDude wrote:I've been able to terminate programs fine on Vista, but haven't tried WinZip Quick Pick. Might want to make sure the title is exact - or try this way...
thank's
SynthaxError wrote:Work great now
Hi, I am new to IA and have the need to terminate a process which does not have a UI, just the ProgramName.exe.
Would you or anybody else post the exact code on how to do this in IA?
I have tried the IA Terminate Program, but that is not working for my case.
Thanks!
Edhy Rijo
Re: Check Process and Terminate it if it's running
Gizm0 wrote:A small script to check if a process is running and terminate it.
<a>checkterminateprocess.mia
Can someone please repost Gizm0's file for the sample script from above. I registered and I still cant access the file.
I'm looking to terminate outlook too and this script would be instant for me.
thanks
DC
thanks
DC
DC
Hi Panagiotis,
The link to the file is not working fine, I am not able to download the script, all I get is an .html reference when trying to Save As, see picture attached.
Edhy Rijo
Same here. link is not working...
it seems redirect to the index page of www.installaware.com
Ok, it looks like a cookie issue.
Instead of browsing to forums from www.installaware.com/forum/, browse to http://forums.installaware.com and login from there (you'll probably be redirected to installaware.com/forum again, but if you browse back to forums.installaware.com, you're already logged in). Navigate here to this thread and try to download again.
It will work now.
It will work now.
Users browsing this forum: No registered users and 20 guests
