Solved: Microsoft Azure Intune MSI Upload failing
oholthau
Postby oholthau » Mon Feb 26, 2018 5:51 am
Microsoft Intune allows a Line-Of-Business Application to be uploaded.
You can reach it this way:
Mobile-Apps - Apps - Add - Line-Of-Business App - App package file.
If I select a InstallAware created MSI, it is not possible to get Information or klick to OK.
What should I do?
oholthau
Re: Microsoft Azure Intune MSI Upload failing
Postby oholthau » Tue Mar 13, 2018 10:07 am
I got an answer on an inquiry at Microsoft:
• This issue has been determined to be on the backend and a fix is being developed.
• The update will at the earliest be deployed in the 1804 release which would be late April.
• Workaround is using Silverlight portal advised until the release/update.
The generated InstalAware MSI files are OK!
Users browsing this forum: No registered users and 34 guests
