Starting Location of MSI
elabacus
Post by elabacus »
If I create a MSI, since I enabled "Build MSI outputs instead of EXE outputs", I not able to query the correct location of the MSI itself during execution.
When I query the variable MSIFILE, and display it in a MessageBOX,
I get a location as c:\Users\xxxx\AppData\Local\Temp\Mia1\OriginalMSIFileName.MSI
If I try to query EXEDIR, and display it in a MessageBOX,
I get a location as c:\ProgramData\mia2BC6C.tmp
The actual MSI I started is in a subfolder to C:\InstallAware
Is there a way to get the location of the MSI that is started ?
