I'm using InstallAware X6 (4.13.2017) and when I have two installer builds running at the same time both doing code signing it always gives the following error: "Error during build: Code signing failed!"
I can provide any additional information required and thanks a ton for the assistance!
X6 Code Signing Failing - Multiple Builds
Re: X6 Code Signing Failing - Multiple Builds
If you are using a timestamp server it can help to switch to another time server. Happens to me too... most of the time the issue resolves itself after a few days.
I see the problem even when i'm running two builds at the same time that are code signing with different time stamp servers. So switching to another doesn't seem to resolve the problem.
I've ran into it too. If it's an SH2 certificate, the time server that never fails for me is http://timestamp.comodoca.com/rfc3161.
If you haven't already, you might try the standalone Intallaware codesigning app and find the one that works the best and then use it in your installations from there.
Users browsing this forum: No registered users and 213 guests
