Unable to Install X9
glenharvy
Post by glenharvy »
I downloaded and ran the Full Installer (+2.9gig) but during the install I noticed I was about to run out of disc space on the C Drive. I then chose to cancel the installation and after some time and confirming the cancellation, IA finally exited gracefully.
I then ran the Installer again and received the following error message:
I have tried everything I can think of to clean up the installation, rebooted a couple of times and prayed to the IA gods without any luck.
I would appreciate any assistance that you can offer in an effort to fix this issue.
I suspect there are some installation files still in existence as I have lost +6gig of disc space since running the initial install.
glenharvy
Re: Unable to Install X9
Post by glenharvy »
I should have realized/remembered that IA created a separate directory under ProgramData where it installed the installation files. Once I deleted that directory, :) re-installation proceeded beyond the error message.
